BELT SLAPPING ON HOUSING
Old Nov 24, 2000 | 07:53 PM
geno's Avatar
The belt on my 98 sp500 (no EBS 2800mi)had been slapping against the housing since this spring. I had it into two separate dealers for related work and asked both to check the belt. The answer I got was "the slapping sound was normal, don't worry about it". Well I ended opening up the belt shroud after a hole got punched through it from the belt and guess what!
Hope this post helps someone else to save a couple of bucks. Meanwhile, I think a couple of my nephew's need some more education on proper gearing for riding applications.
later'
geno
Old Nov 26, 2000 | 04:50 PM
floodrunner's Avatar
You found out the hard way geno. The belt slapping on the housing is NOT normal and usually indicates a burned spot from being in high when conditions require low. Besides educating your nephews I’d start shopping for a dealer other than the two who blew you off.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
nastyblaster100
Sep 13, 2015 01:19 PM
