Rancher idle setting question
Old Nov 25, 2000 | 09:57 AM
texasrancher's Avatar
When idling in first gear, my rancher es tends to try to creep forward every few seconds. It's like its on the verge on going forward but not quite. Is my idle out of adjustment? If so, how do you adjust it, and where is it? Thanks...
Old Nov 26, 2000 | 08:24 PM
TerryM's Avatar
My Rancher used to inch ahead a bit at idle in gear to and I adjusted my idle down a bit and now it is fine. The idle adjustment screw is right on the bottom of the carb, and has a plastic **** so you won't need a screwdriver. You might also want to check you clutch adjustment.
Old Nov 27, 2000 | 03:40 AM
snowshark's Avatar
I encountered the same thing. Adjust you idle down a little.
Cole Hadden
Jun 15, 2025 09:05 AM
Scottma518
Jul 16, 2015 09:19 PM
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
RedRancher
Jul 10, 2015 06:36 PM
