What would you rate the Raptor 350
Old Jun 17, 2006 | 03:19 AM
havenonickname's Avatar
Default What would you rate the Raptor 350
1 through 10 and if you did mostly trails
Old Jun 17, 2006 | 03:52 AM
I need your opinion
Old Jun 17, 2006 | 04:24 AM
lildeezul's Avatar
Old Jun 17, 2006 | 06:08 AM
they just as good as a blaster if not better
Old Jun 17, 2006 | 09:28 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
all depends on the rider.. i can keep up with anything in th etrails. and climb any hills i want to
Old Jun 17, 2006 | 01:57 PM
recon99's Avatar
For trails i'd give it an 8. The only complaints I have with the 350 on the trails is that the shocks are on the bumpy side.
Old Jun 17, 2006 | 04:31 PM
YamiYFZ's Avatar
4 sounds good
Old Jun 17, 2006 | 05:45 PM
Speedy2222's Avatar
that's the main problem with rapto350/warriors is the stock fuc|Cing suspension... now the rear shock isn't bad but the raptor helps.. btw now that my rear shock is properly broken in it rubs the linkage.. idk if it's just super loose or what.. i will check it out tonight.. it is also maknig some weird noises when i turn
ReconBayou
Oct 31, 2022 05:37 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
fredrikrosen
Sep 28, 2015 09:58 PM
black_thunder
Sep 22, 2015 07:59 PM
black_thunder
Sep 6, 2015 04:41 PM
