Sportsman 500 Overheating
Old Jun 26, 2006 | 02:33 PM
RacerSteve's Avatar
Default Sportsman 500 Overheating
I have an 2005 sportsman 500 ho, and I was riding it this weekend and it overheats. The radatior is full and not pluged and the fan was running.
Old Jun 27, 2006 | 05:10 AM
Instigater's Avatar
Are you positive it actually overheated? The indicator would give a false alarm on some of the 05's. You can do a search on this forum to see what others have discussed.
Old Jun 27, 2006 | 08:04 AM
upnort's Avatar
Are you sure rad not plugged? It can look clear from the front but be plugged up in the rear where it builds up against shroud also washing it from the front forces the stuff to the back fins.
Old Jun 27, 2006 | 09:40 AM
floodrunner's Avatar
Yep, what he said. The best thing you can do is twice a year remove your fan, then your fan shroud (only four bolts each) to get behind the radiator and wash it from both front and back. I can have the two pieces out of the way in about as much time as it takes to jack up the machine and take the front wheels off. With the wheels out of the way you can get in behind the radiator better. The fan and shroud slip out through the right side. Well worth doing.
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
