2003 raptor 660 cutting out
Old Jun 26, 2006 | 05:33 PM
4wheel4food's Avatar
Default 2003 raptor 660 cutting out
A buddy of mine I ride with has a '03 raptor(i have a '03 warrior)....
his bike has a bad tendency of cutting out(gas sputtering) when we go
up hills in the trails...anything from 5-50' high hills...my warrior goes
right up them with no problems...any ideas what might be causing this...
i've ridden his bike several times and it seems like it just not set up
very well for trail riding....you can do wheelies and go 70mph, but not
a very good trail experience...he is thinking about dropping down to a warrior,
because we mostly trail ride and he has no need ofr speed like most raptor owners...
he likes the raptor becasue he is 6'6" and about 250, so it has plenty of "leg room" and
power...any thoughts would be appreciated....
Old Jun 26, 2006 | 06:13 PM
keist08's Avatar
when my jets were clogged my would sputter out but it would do it all the time.
Old Jun 30, 2006 | 07:16 PM
03RaptBlu's Avatar
I have somewhat of the same prob with my 03 660R.......except mine is with jumps....when i jump and I am in the air, i cant give it gas due to sputtering and the same with landing! someone please help with this problem! (i have all stock parts and just cleaned my jets and its still doing it)
Old Jun 30, 2006 | 07:17 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i know in mny warrior carb.. there was this plastic splash guard... if you took that out when you rejetted... that's your problem...
Old Jun 30, 2006 | 07:21 PM
03RaptBlu's Avatar
do you know if the raptor has that and if so...what does it look like and where in the carb is it? I have heard that it is an issue with the vaccums closing shut....any ideas?
Old Jul 1, 2006 | 02:59 AM
albaraptor660's Avatar
I would check float levels if the quad is on a incline and the levels are off this would explain the sputter. There is a clear tube way of cheaking the float levels on both carbs without taking anything apart. Do a search for this method or check raptortranny.com The raptor makes a great trail quad and you should not be having this problem. Happy 4th to ya.
Hw00d
Sep 10, 2015 08:53 AM
1ArmBandit
Sep 8, 2015 08:59 PM
chewy78
Sep 8, 2015 10:37 AM
black_thunder
Sep 7, 2015 01:24 AM
Elkaholic
Sep 6, 2015 02:44 PM
