REAR AXLE ON BLASTER WOBBLES
Old Jun 27, 2006 | 01:44 AM
yamahablaster23901's Avatar
Default REAR AXLE ON BLASTER WOBBLES
i went riding one weekend and i went to go make a left turn on my 2001 yamaha blaster and i heard a grinding noise coming from my back end around my axle. i thought it could have been my bearing. so i went home and lifted it up and my whole back axles wobbles. i was wondering what could have happend and where i could order bearing for it if it is the bearings.
Thanks alot!!!
Old Jun 27, 2006 | 07:02 AM
enFORCER's Avatar
Yep, sounds like you need new carrier bearings. You can get them from a dealer or online.
Old Jun 27, 2006 | 03:16 PM
if i were to buy Rear axle bearings would that fix it or do i have to buy a new carrier. im not sure wether the axle bearings are the same as the bearings in the carrier. thanks for th help
Old Jun 27, 2006 | 03:44 PM
SSTSprint's Avatar
All you need is rear carrier bearings, expect to spend around 50 bucks for everything you'll need.
Old Jun 27, 2006 | 04:15 PM
fasterthanyou22's Avatar
If it wobbles badly, then you may have shattered part of your carrier. Thats what just happened to my brothers z400.
Old Jun 27, 2006 | 07:52 PM
silent101's Avatar
i would look on ebay i got my bearing on ebay for 20 bucks shiped and my axle was wolbing bad so im sure thats you're problem.
Old Jun 28, 2006 | 12:53 AM
Boomer2's Avatar
When you replace those bearing put in a grease in the carrier to make em last longer, sounds like you ride hard. Theres a how-to on Project Blasterin the forums section.
Old Jun 28, 2006 | 01:10 AM
woodsracertofast's Avatar
here is a tip, put your bearings in the freezer overnight and install them while still frozen,it shinks them temperarly and is so much easier,sounds crazy but it works.
STLyamwar
Jul 25, 2020 04:44 AM
bigred20653
Aug 31, 2015 12:41 PM
Dammar
Aug 26, 2015 07:12 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
