Valve Adjust Question
Old Jul 7, 2006 | 11:28 PM
RuninWideOpen's Avatar
Default Valve Adjust Question
Hey, all
Im getting ready to adjust my valves for the first time on my 06 kfx700 my Question is how do you guys Torque the locking nut and hold the adjuster at the same time ? do you guys torque the nut or just make sure its good and tight using a wrench and a screw driver
Old Jul 8, 2006 | 12:32 AM
mojo21's Avatar
I just do the wrench and screw driver method. I use a feeler guage to get the right adjustment then snug it up. The heat from the motor makes it tighten even more and never come loose in most cases. Hope this helped. Good luck!!
Kenny
Old Nov 10, 2006 | 10:17 AM
Gus13's Avatar
I bought these when I adjusted my Wolverine and they helped out a lot! Tappet tool set
I just bought a 2004 Twin Peaks/Prairie 700 with 600 miles on it, I forget how many hours. He had the valves adjusted at the time they recomended I think 100 miles. It is two years old and was wondering after the initial time of having them checked/adjusted how often they should be checked/adjusted. I do here like a tapping but sounds like it actually may be comming from the side where the belt/transmision is. He has a clutch kit in it if that means anything to make noise.
Does anyone have the process for the Prairie 700 since it is a V twin? I noticed under the seat were the valve clearance specs. I am sceptical to do it on this one, the Wolverine was easy.
Old Nov 10, 2006 | 02:32 PM
Hayashi's Avatar
Whether V-twin, parellel twin, single, the valve adjustment is all similar if not same on these metric quads.
For front cyl:
1). Set the crank to TF mark, which is the end of the compressiong stroke.
2). Open the valve inspection cap
3). Loosen the locknut with 10 mm wrench
4). Adjust the slotted screw to the spec.
5). Tighten the locknut while holding the slotted screw.
For real cyl:
1). Set the crank to TF mark.
Steps 2-5 are all same.
Get a genuine Kawi service manual which will be the most important investment you will ever make for your quad.
Old Nov 10, 2006 | 03:26 PM
Gus13's Avatar
Thanks. Yeah, I went to the dealer and priced the SM and was $53. I will be sure to get one soon.
What efforts does it toake to get to the valve covers?
How often should the valves be adjusted?
You must turn the engine CCW correct?
Old Nov 10, 2006 | 07:50 PM
PurePrairie's Avatar
V-Twin Valve Adjustment
Old Nov 11, 2006 | 12:09 AM
Gus13's Avatar
Thats a great write up, thank you. I think I may check mine tomorrow.
So there are 2 in each cover? You have to adjuste them both correct? In my wolverine there was only one in each.
What is the intervals to have them checked/adjusted?
Old Nov 11, 2006 | 12:56 PM
Gus13's Avatar
I just got done checking mine and they were all in spec except for one of the rear intake, I adjusted it to be equal to the one next to it. Thanks for the helpful info. The rear cyl. wasnt bad at all, took the plastics around the air filter off (two bolts) and battery (3 bolts) and it was all right there. The front one I had to removed the airbox (could they have put anything more bolts or hose attachments to the airbox?[img]i/expressions/face-icon-small-shocked.gif[/img]) then they both were right there. The front exhaust port was the most difficult to get to.
How often should the valves be checked?
Old Nov 13, 2006 | 12:37 PM
Hayashi's Avatar
In my experience, Kawi's V twin engine needs valve check/adjustment about every 50 hours of usage to prevent any top end damages like valve digging into the valve seat of the head and/or breaking the valve head from its stem. Also, properly adjusted valve will give you easier starting because the head can breathe better.
Old Nov 13, 2006 | 12:47 PM
Gus13's Avatar
Great thank you. I will be sure to check/adjust them every 50 hours.
Yes, I did notice when engine is cold I have to start it with the choke all the way on and it does take it a little to warm up before it runs good. Once warmed up starts right up. Maybe it is more of a warm blooded animal, where my Yamaha Wolverine was more cold blooded, I barely had to use the choke on it.
Is that normal on these?
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
yambam13
Jul 4, 2015 01:49 PM
