More questions
Old Jul 14, 2006 | 08:32 PM
Joshwfl's Avatar
Default More questions
So I pulled the valve cover off today planning to remove the cylinder to check the piston clearance and ring gap. When I went to put it back on it wouldn't sit flush again. I spent an hour and a half but no matter what, it wouldn't go back. The front right corner is sitting about 1/8" off the top of the cylinder and won't go farther. Any sugestions?
Old Jul 15, 2006 | 12:20 PM
duffus's Avatar
valve cover-- not the head, correct?
make sure you have it rotated the right way-- ie try it 180 degrees from how it is now.
Will it sit flat on a level surface-- like a counter?
Old Jul 15, 2006 | 06:53 PM
Joshwfl's Avatar
Yeah the valve cover. It's sitting flat on my work bench. I tried rotating it 90 degrees 4 times and it still wouldn't sit correctly. Everything is lined up, it doesn't make sense.
Old Jul 15, 2006 | 11:15 PM
Mainboard's Avatar
did you check to see if anything was up out of the engine it self..any thing sticking out ..maybe somthin poped out of place..
Old Jul 16, 2006 | 03:51 PM
Joshwfl's Avatar
Found it. The bearing on the end of the cam has a pin that has to slide down into a slot to sit level.
Next question:
I have the cdi cover off and the pulse generator removed, now the the spark advancer won't budge. I have removed the bolt and the main part slid off the shaft, but the internals won't slide off the cam. I can't remove the cylinder until it's done!
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
