LRD P700 Problems
Old Jul 15, 2006 | 01:27 PM
barracuda's Avatar
Default LRD P700 Problems
Purchased a slip on LRD exhaust for my Prairie 700. Had two problems installing it: (1) The stock muffler mounts to the atv with two bolts close to each other installed from the side of the atv. LRD muffler uses one of those same mounting points and has a second mounting point at the end of the muffler where the rear rack is bolted to the frame. The bracket welded to the LRD muffler is not shaped correctly. The bracket hits the rack and will not allow the muffler to be raised high enough for the bolt to line up. About a 2" long section of the bracket must be filed down about 1/2". Since I do not have a bench grinder or air grinder, had to file it by hand. This took about two hours of filing and test fitting until I got it right. (2) LRD header pipe has a clamp welded on where the LRD pipe slips over the stock front header pipe. The screw would not go into the clamp because the threads are no good. Does not seem to matter because the two pipes slide together so tightly there is no exhaust leak even without the clamp tightened.
05 P700
26" Goodyear Rawhide MTR tires
LRD exhaust
Twin Air filter & cage
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
