kfx 400 carb
Old Jul 22, 2006 | 06:53 PM
06kawasaki's Avatar
Default kfx 400 carb
how do you get the freaking screws out of the bottom of the carb?!?!?!? i try and i just strip them out......any suggestions???
Old Jul 22, 2006 | 09:20 PM
knauf's Avatar
I got mine out with a small needle nose vice grip. You might want to search the forums as I remember a few posts on ways to get them out.
Old Jul 22, 2006 | 10:03 PM
06kawasaki's Avatar
ok...thanks alot. i will give it a try!
Old Jul 23, 2006 | 12:24 AM
rehm436's Avatar
If they are not totally stripped out go to your local tool store and buy an impact-screwdriver set. $20 - 30. When you hit it with a hammer it hammers in an turns at the same time. but don't use any thing larger than 16oz ballpeen. also anytime I take something apart with steel screws or bolts in aluminum that hasn't been taken apart in a while , I will always tap on the heads with a hammer after soaking with wd-40 for a while. Good luck.
Old Jul 23, 2006 | 12:40 AM
hondabuster's Avatar
You need to buy a ACR Philips screwdriver or bit. The ACR stands for anti camout ribs. They really do the trick, to keep the philips heads from rounding out. They even can work on screws which are already buggered up.
As long as youre replacing them, buy stainless socket head cap screws..they wont corrode, and the allen slot wont round out.
Old Jul 24, 2006 | 12:34 PM
rdlsz24's Avatar
I turned mine into straight slot screws with a Dremel and then replaced them with Allen head bolts after rejetting.
Rob
Old Sep 25, 2006 | 02:04 PM
Sickwilly's Avatar
I had to get mine out with needle nose visegrips. It sucked!!!!!!
But i replaced them with steel allen heads and they work alot better.
It's just not an easy carb to get to.
'06 kfx -Orange
yoshi pipe
Jet kit
K&N
outerwears
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
