350 HELP
Old Jul 22, 2006 | 07:07 PM
2FAST4URASS's Avatar
Default 350 HELP
2005 raptor has no fire threw the wire ive checked and checked and did the red neck test with the screw driver in the plug wire test no juice what so ever what could be the problem were should i start looking for the problem any help would be great thnx. JEREMY
Old Jul 22, 2006 | 11:57 PM
RDZ350's Avatar
Default 350 HELP
I'd just try changing the plug.The screw driver check might be wrong.
Can't say that I've never tried it.Yes,I'm guilty.LOL!
Did it do it while you were riding or after it sat for a while?
Old Jul 24, 2006 | 02:02 AM
Default 350 HELP
It happend whille i was riding down the road about 20-30 miler per hour just takeing it easy and burrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr it came to a hault i got off checked to see if it was getting fuel and it was then changed the plug tried with out luck so i pushed her home.It happen about 10 minz after i had it crunk up but i ride it daily atleast for an hour our two playing around in the yard...
Old Jul 24, 2006 | 02:10 AM
quicksilver's Avatar
Default 350 HELP
I'm not calling you stupid... but the kill switch is on right?
otherwise check your ignition coil.. should be 2-wire connector on it, measure with an ohm meter in ohms mode, measure across the terminals of the coil. Should have some continuity (consult a manual for spec's) a complete open in the circuit would mean a faulty coil. Also check around the stator for any loose connectors or grounded wires.
Old Jul 24, 2006 | 05:36 AM
JLsparky7's Avatar
Default 350 HELP
spray out carb
change plug
fresh gas
clean filter
Usually the problem isnt electric.
