Sport Quads Discussions on sport quads.
Does this sound like dirt in the carb
Old Jul 24, 2006 | 10:27 AM
staggarlee's Avatar
Default Does this sound like dirt in the carb
I was riding on a very muddy track yesterday and my LTZ-400 was running strong and then it would just die. I could eventually get it started and it would run strong again for a short period then die again. Does this sound like dirt got into the carb jet? Is this something an amateur mechanic can take apart and check?
Old Jul 24, 2006 | 03:56 PM
bombrider04's Avatar
Do you have enough gas? I would prob tell you to first check the airfilter making sure that it is clean and isn't wet because if it was wet that is what I think it is but I will put other stuff that it could be just incase. But if it happens that this isn't the problem then it would sound like the carb there are a few things you can do. I would start off by checking the diapragm for any small tears or rips and if that does look fine then check this. Take some carb cleaner and take the jets out of the carb and spray some carb cleaner into them cleaning any dirt inside them. If that seems fien then try checking the float on the carb and adjust that, check the petcock for any clogging in the fuel line, and last check the spark plugs. Here is a site that will show you the carb. If you have any more ? pm me or something good luck.
Brett
http://216.37.204.203/Suzuki_OEM/SuzukiATV.asp
Old Jul 24, 2006 | 10:02 PM
Doctorturbo's Avatar
GOT BOOST!
Could be a zillion things; but the VERY first thing I would check is the carb fuel vent line. Sounds like a venting issue to me.
Old Jul 24, 2006 | 10:59 PM
staggarlee's Avatar
Thanks for the replies and tips. I have got as far as removing the gas tank and petcock. That looks good. The air filter is dry and clean. I will inspect the jets tomorrow.
Old Jul 25, 2006 | 02:45 AM
The airfilter may have been wet at the time and restricting airflow so before you go taking the carb apart try starting it back up.
Old Jul 25, 2006 | 09:23 AM
staggarlee's Avatar
I did try starting it plenty of times later on that day and the following day. There also wasn't signs that water had been in there.
Old Aug 26, 2006 | 10:21 AM
CAM300ex's Avatar
My old honda 90 fourwheeler did the excact same thing. I took it to my local honda dealer and they couldn't fix it the 3 times we took it there. Then i figured out that there might be dirt in it and so we took the carb apart and there was tons of dirt in it. Now it runs fine once we got it all out.
Old Aug 27, 2006 | 08:13 PM
staggarlee's Avatar
It did end up being dirt in the carbs for me too. I found all kinds of dirt in the float bowl. I sprayed out the jets with canned air and replaced. It started right up.
Frisky2050
Apr 9, 2020 11:19 AM
cSchwartz
Jul 12, 2015 07:42 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
