Honda 400 ex problems
Old Jul 24, 2006 | 09:44 PM
Honda400exster's Avatar
Default Honda 400 ex problems
I have a 2000 honda 400 ex, the only problem,s im having with it, are that when i drive through a water hole i can get through it fione but when i get out it starts to sputter and loose tons of power and sometimes stalls and also i went through a water hole today and i drove it home and now it wont even stsrt it ran a couple times but backfired and died.
Old Jul 25, 2006 | 12:28 AM
nightowl24's Avatar
i'm new to four wheelers but not new to engines in general..it sounds like some how water is getting to your spark plugs...my cousin's polaris was doing the same thing, when he took it in to finally get it fixed they guys said that some how water got in the engine and was fouling out is spark plugs....
Old Jul 25, 2006 | 01:05 AM
1988fast250x's Avatar
drain ur oil put fresh filter and then run it for like 20 min then do it again.... This needs to be done!! also change spark plug,, should solve ur problem.. Also clean airfilter really good.. hope this helps.. should solve it no problem... If not let us know..
Old Jul 25, 2006 | 10:55 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
How deep of water are we talking?
Old Jul 25, 2006 | 11:07 AM
hondaman0045's Avatar
Ya, if its deep water i would just stop all together, its not made for that. If u want to go mud boggin get a 4X4.
-hondaman0045-
Old Jul 25, 2006 | 03:22 PM
not even that deep im talking mabe 1.5 to 2 feet at the most but ots when i go fast through it after i get out is where it dies.
Old Jul 25, 2006 | 04:23 PM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
It's sucking it in from the airfilter. Your hitting it to hard and splashing it up into the intake. Check out your airbox for water and clean your filter and let it dry before oiling it.
Old Jul 26, 2006 | 01:14 AM
vd's Avatar
vd
sounds like you got alot of loose air box connections and or exhaust. i would tighten them up.
Your air comes form the top of your frame by the handle bars.
My buddy used to sit in 3 feet of water shut his wheeler off help me out and then start his 400ex right up and drive out no problems.
Old Jul 26, 2006 | 01:27 AM
nathanpri08's Avatar
Recomend an outerwears prefilter helps water.not waterproof but water repellent.still helps but i dont think its your problem.I agree with most answers spark plug wires.I had my old 2001 ex in over three foot of water and barley made it but it still ran at the end of the day.Wouldnt recomend to anyone beat the sh*t out of her and it kep on ticken.BELIEVE IT OR NOT!
Old Jul 26, 2006 | 12:41 PM
nofear17bmx's Avatar
I am having this same problem. I didnt know it could be because of the spark plug but I did notice I had about 1/3 of an inch of water in my air box. It stalled for me...but after cranking it a bit with some dry air through the cycle it started up and took a bit before it ran stable.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
