2002 trailboss swing arm
Old Jul 25, 2006 | 12:07 PM
carp886's Avatar
Default 2002 trailboss swing arm
How do I get the Left Pivot Bolt out? The bushings are really worn. Swing arm moves around a lot. Looking at the quad from the rear can`t even see the left pivot bolt. But I know it has to come out to remove the swing arm. Lost on what is next move. Don`t like the ideal of taking it to a dealer.
Old Jul 25, 2006 | 07:06 PM
ftwflh's Avatar
You have to pull the clutch cover off.
Old Jul 27, 2006 | 10:40 AM
carp886's Avatar
Ok I pulled the belt cover off. Does the cluth have to come off and the trans. pully pulled off? Also there seems to be another black plastic plate still covering the pivot bolt.
Old Jul 27, 2006 | 07:07 PM
ftwflh's Avatar
You have to pull both clutches and inner and outer covers.
Old Jan 10, 2007 | 01:39 PM
F150SKE's Avatar
How hard is it to pull both clutches and both covers off? Are any special tooks needed? I need to change my swingarm bushings also.
Old Jan 13, 2007 | 10:58 PM
Bad2WD's Avatar
It's not real hard but you will need a clutch puller for the primary clutch and you may need one for the secondary. The pullers are not the same for each clutch. Make sure you get the puller for a trailboss on the secondary. I had to shorten the one I bought for the secondary as it was to friggen long. It takes about two hours to tear it down and about the same to put it back as long as it goes smoothly. I thought the plastic parts would be bad in mine but they looked fine. It was the brass parts that were worn out. I would go ahead and change all of them. You will need a torque wrench and a 2", 1 3/4" and 1 5/8" socket and combo wrenches.
Download the service manual from my sig and you can see how it is done.
95wolv
Sep 27, 2024 12:00 PM
fd24
Jan 16, 2019 08:59 AM
atvcollector
Sep 8, 2015 05:11 PM
byronman
Sep 6, 2015 06:34 PM
