loose ball joint on KMZ 150
Old Jul 30, 2006 | 03:24 PM
Noxzema's Avatar
Default loose ball joint on KMZ 150
My Ball joints on my 2005 Kazuma KMZ 150 are very very loose with a lot of freeplay especially the ones on the upper A arms. They are probably ready to break! They don't appear adjustable like the castle nut on the tie rods, or is there adjustments you can make under the boots? Has anyone replaced theirs? and where did you get the parts?
Mine have been getting looser and looser and I don't want them to break on the trails!
Thanks
Old Jul 30, 2006 | 11:14 PM
2manytoys's Avatar
There is no adjustments on the ball joints. The ball joints are pressed into the a arms with a big c clip holding them in. You need to get new ball joints and put them in. Just make sure you keep them greased.
Old Jul 31, 2006 | 06:46 AM
Noxzema's Avatar
Thanks
there appears to be 3 nuts holding the ball joint to the A arm. It comes apart from the arm apparently. There are no grease fittings. Did you just add a fitting?
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
jankerstien
Sep 21, 2015 03:09 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
89Lt250r
Sep 7, 2015 07:53 PM
