Mojave Bogging out?
Old Aug 5, 2006 | 12:18 AM
jray3369's Avatar
Default Mojave Bogging out?
My 02 Mojave runs and starts great. But when it is just sitting there idling, if i rev it up real fast from an idle it will bog and die? Any suggestions? Thanks Jordan
Old Aug 5, 2006 | 01:26 PM
nomorenicknamesleft's Avatar
now i aint the best at working on atv's kinda knew but maybe a carb clean...or maybe even your jetting is off....ide ask rolsmohave3 or holeshotz8436 pm them they will know
Old Aug 5, 2006 | 03:07 PM
jray3369's Avatar
Its completle stock and has low hrs on it. It climbs and races good but just if you punch it in N it will bog and die.
Would it hurt if i ran a higher grade fuel in it? The book calls for 87 i think and i have 89-92 at times. I could try the carb again...
Jordan
Old Aug 5, 2006 | 03:36 PM
paintballbanshee's Avatar
try draining and cleaning carb and yea do 87 octane
Old Aug 5, 2006 | 11:16 PM
holeshotz8436's Avatar
the compresson ratio on a mojave is 11:5:1 so it needs 93 octane minimum.......
Old Aug 6, 2006 | 01:10 AM
rolsmojave3's Avatar
does it do it more so with the choke on or off? May need a piolet jet a size bigger, or mess with the mixture screw till it's happy
Old Aug 6, 2006 | 01:18 AM
jray3369's Avatar
choke off, i havent tried it with it on? Im going to do the carb tomarrow i had a wedding to go to today. Jordan
Old Aug 6, 2006 | 02:07 PM
Chris142's Avatar
The sticker on my 02 Mo said 91 octain or higher. I don't think thats your problem. Prolly a gummy carb.
Adjust the valves too while you have it apart. Very important on the Mojave and needs to be done often.
Old Aug 7, 2006 | 06:39 PM
MojaveMark's Avatar
I had the same problem. I just took of the fuel bowl, and cleaned all three of the jets, I think they are the pilot main and starter jets by name, checked the valves and set the air screw to 2 and a half turns out. That took care of all my problems coming of idle, but created a new. Now the front wheeles keep coming of the ground couse I'm not used to the better throttle response, but that could be a good thing.
Old Aug 13, 2006 | 08:46 PM
jray3369's Avatar
Well I got around to taking the bike apart. I went riding yesterday and all was well and today I went to pull the bike out and when I hit the throttle it would bog down and die. Not stumping on it just to go. So I took it apart and put it back together and it’s doing the same thing.
What its doing exactly: Starts with the choke on, idles some what with the choke off. When you hit the throttle slow or fast it dies right away.
My original post was just a bog when you would punch the throttle off idle it would bog a little and either get up and go or die. Now I can’t even rife it.
Any help would be great. I really don’t have the money to take it in. Thanks Jordan
