Udjusting the chain on ds650x
Loosen the bolts on the back of the swinger... then there is a hole in either the brake or in the sprocket hub (can't remember which side)... put an allen or screwdriver threw the hole into the hole in the axle carrier... the axle is offset so when you turn the wheels the chain will tighten/loosen.
Yep...thats pretty much it...there are 4 bolts on the rear of the swing..loosen all them and then the sprocket hub has uhhh 2 or 3 holes in the arms where you can put a bolt that size or whatever..then to tighten you pull the quad backwards and to loosen you push it forward.............. then tighten up all the bolts and she is set.
make sure you still have some slack in the chain when tightening it and the carrier when looking at it can see one side has more metal then the other the side with the holes if you turn the carrier too far you will run into having the chain hit the skid plates if you have that problem just turn the carrier 180 degrees and itll be fine .
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
