Praire 360 belt light reset procedure??????
Old Aug 9, 2006 | 10:33 PM
wingshooter's Avatar
Default Praire 360 belt light reset procedure??????
Can anyonr tell me the reset procedure for the belt light on the Praire 360?
Old Aug 9, 2006 | 11:07 PM
kfxandahemi's Avatar
Here you go...
. Turn the ignition switch OFF.
2. Disconnect both sets of 5 pin connectors located above the CVT cover. Note: These connectors are located just beneath the shift handle on the right side of the 650; one is black and one is grey.
3. Connect these 5 pin connectors to their opposite pairs (grey to black and black to grey).
4. Turn the ignition switch ON.
5. Disconnect the belt failure switch at the 2-pin connector above the CVT cover. (Note: Just follow the wires coming from the rectangular black box on the CVT Cover to locate this connector.)
6. Observe the belt-warning lamp. It should be flashing at a 0.4 second interval for a few seconds then start to flash slower. Let the lamp flash for at least seven seconds.
7. After seven seconds or more, turn the ignition switch off.
8. Reconnect 5 pin connectors to their proper location (black to black, grey to grey).
9. Connect the belt failure switch 2-pin connector (wires from CVT cover).
10. Turn the ignition switch on to confirm that the belt warning light is not flashing. Retry this procedure if needed. As far as I have heard it always works if the belt switch isn't tripped and there are no electrical problems.
I think this is right, if not please jump in if I missed something.
Old Aug 9, 2006 | 11:38 PM
thanks I will give it a try.
Old Aug 11, 2006 | 07:54 PM
tencubed's Avatar
Being retired is a hoot!
Originally posted by: kfxandahemi
Here you go...
bump
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
