KFX700 Oil and Coolant Questions/Capacities
Old Aug 10, 2006 | 04:08 PM
vdubn's Avatar
Default KFX700 Oil and Coolant Questions/Capacities
Can anyone tell me what the oil capacity is for the engine, and also for the shaft drive/rear end? Also, how much coolant and if I can use std green antifreeze?
What weight oil do most of you use in your engine?
Thanks...
Old Aug 10, 2006 | 08:47 PM
kfxandahemi's Avatar
I havent messed with the coolant yet, I plan on putting some engine ice in it later, but I do know about the oil. It holds right at 2 quarts and I have been using 10-w40 royal purple oil. Royal purple stays really clean and works well. I think that the actual oil capacities is 1.9L with the filter removed and 2.2L completley dry. There should be a tag right about the oil fill that says all the info on it.
Old Apr 23, 2009 | 07:55 PM
fourgs's Avatar
Default KFX700 Oil and Fuel Capacity
Oil Capacity: 2.2 qt
Fuel Capacity: 2.7 gal.
Old Apr 26, 2009 | 12:41 PM
the green kow's Avatar
rear final gearcase - 0.95 us qt.
use kawa chem gear and wet brake oil , may also use the following
mobil fluid 424 , citgo transguard tractor hydraulic fluid or exxon hydraul 560
coolant cap. -2.64 us qt.
oil- 10w-40
1ArmBandit
55
Oct 14, 2015 09:03 PM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
