DS starts but will not run???????
Old Aug 12, 2006 | 01:01 AM
Stickhauler's Avatar
Default DS starts but will not run???????
Hi all, I just picked up an 01' DS 650 from a buddy of mine. The machine has been sitting for approx 2 years. I cleaned the carb and all jets, and installed new spark plugs etc. The quad will start up, but as soon as I let off the starter button it will not stay running. It is not getting any spark unless the button is held in. What is up with this? Bad CDI or something less expensive? Could it be corrosion somewhere? Please Help!
Thanks,
Jason
Old Aug 12, 2006 | 01:44 AM
bombrider04's Avatar
hmm to me it sounds like either a bad cdi or a loose ground does it actually run or does it crank over and thats it
Old Aug 12, 2006 | 02:16 AM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
Test the battery, If it has sat that long with out a battery tender the battery may be shot. The DS's must have a good battery to run right.
Old Aug 12, 2006 | 08:54 AM
Yes is actually does start but then dies. The battery is junk. We were using a battery charger on it to get the machine to roll over. Thanks for the replies, guess I will go buy a new battery.
Old Aug 12, 2006 | 07:17 PM
learnem's Avatar
dont do a stock battery....they suck bad
Old Aug 13, 2006 | 01:20 AM
MrMeaner's Avatar
Ive had a stock battery since I bought mine in 2001.
Old Aug 13, 2006 | 01:35 AM
05dsrider's Avatar
yes it needs a good battery to run even with the charger on it would do that but if you throw a new batt in it starts right up and runs like a champ because we had this problem before n went through thinking it was more than a battery
Old Aug 14, 2006 | 01:11 PM
rfwlll's Avatar
Thanks,
Jason
This is a common problem on a ds650 that has a bad battery, I aswell had the problem with the same effects, and yes a new battery will fix it.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 19, 2006 | 12:00 AM
Yup, that was it. I put a new battery in it and it started right up. Runs great now. Just glad it wasn't and electrical monster!!! Thanks all for the help.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
