clip position new ?
i have a hmf pipe and my bike is running like crap i have the needle clip positioned on the second grove from the top so my question is do you count it from the flat part down or from the pointy side up i think i have it set at no.4 or no. 2 im not real sure.
jonathan
jonathan
you are running a 175 I have a full system with no lid and K&N and am running a 190 try putting a 180 in and see what happens I had a 185 and was running too lean but I fixed it now and once you get that in mess with the screw that is on the left side of the carb and try turning it if you look into the carb its a very small jet on the left side when sitting on it you may find a difference I think that should do it when i turned mine with the 185 it would backfire the when I turned it with the 190 it was perfect
I am not sure just try putting it at different positions and see what works better
