Sport Quads Discussions on sport quads.
Air pressure
Old Aug 16, 2006 | 09:38 AM
bmxatv's Avatar
Default Air pressure
My 400ex manual says to run tires at 4.5 psi. I took the air pressure down to 6 and it almost seemed flat. Is this 4.5 psi rating correct for all around off road riding? It seems kind of low. I pressed on the tire at 6psi and almost touched the rim. What psi shouls I be running? I currently have them at 10 all around.
Old Aug 16, 2006 | 10:11 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I would suspect that your gauge is way off????? What I do is collect all my buddies gauges, and compare them all and come up with an average. If one of them is way off, it is going to be obvious. It is not unusual for gauges to be off by at least 0.5 pounds.
When you are running to high a pressure, you are not taking advantage of the fact that the tires are radials and contribute quite a bit to the suspension/handling of the quad. Lower pressure will also help float you in the soft stuff, but as you pointed out, you don't want to be so soft in rocky terrain that you get a rim pinch.
Old Aug 16, 2006 | 11:38 AM
bmxatv's Avatar
thx. Would you say that a 1/2 lb. or 1lb. over the rated psi would be a good start for all around terrain? Say 5 or 5.5 psi? Will any ordinary air pressure gauge work?
Old Aug 16, 2006 | 06:43 PM
Red Rider
You need a low pressure gauge, say 0-15 pounds. Your dealer should carry them.
Old Aug 17, 2006 | 10:11 PM
bananaman's Avatar
3 to 5 for the soft sand/dirt. 6 to 8 for the hard pack and grass and such.
Old Aug 18, 2006 | 09:11 AM
bmxatv's Avatar
thx re con. i went and got myself a guage and have the tires set at 5 psi. they seem to grip really well now. i like this place. ask and you shall receive.
Old Aug 24, 2006 | 11:30 PM
WheelieRyder01's Avatar
on my ex i run 4.5 pounds in the front all the time but in the back i like to run 3.5 to 4 pounds depending on the terrain.
bmxatv10
Oct 14, 2022 06:23 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Hw00d
Sep 10, 2015 08:53 AM
