BF750 after deep water ride.Any special maint?
Old Aug 17, 2006 | 01:08 AM
kvfcal's Avatar
Default BF750 after deep water ride.Any special maint?
After riding in Azusa Canyon, Ca (Lots of deep water crossings) Is there anything I should do as far as after ride maint?
I flipped through my manual but didn't see anything. Any of you BF folfs have any quick tips? Thanks Calvin
I WANNA RIDE!
Old Aug 17, 2006 | 01:35 AM
FASTFATBOY's Avatar
You may want to check your front and rear differentials. Just to make sure you didn't get water in your diff fluid if you did it'll look milky. Not a big problem usually but you may want to check. If the water was muddy or sandy you may want to wash out the brakes real good. Don't use a pressure washer because it could push trash into the wheel bearings. A water hose with moderate pressure will work fine.
Old Aug 17, 2006 | 01:52 AM
Brute23's Avatar
Yeah I would check you fluids and makes sure there is no water in any of the oils. Also pull your belt cover and check for mud or anything like that. You have diaelectric greae on your electrical connections right? If not do it now. You will get corrosion. If your 2wd-4wd lite flashes in the next couple of day or so start with your fuses and then move on to other connections.
I always carry extra fuses... and not in the bike because those get wet also. Put them in the truck or something so if your get corroded up you can change them out easily.
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
