No Differential?
Old Aug 20, 2006 | 10:02 AM
MotoF150's Avatar
Default No Differential?
OK, stupid question, I had my 06 Suzuki Eiger jacked up on the rear axle and I noticed there is no differential, both rear wheels turn solid. I called the dealer thinking something is wrong with it and he told me thats normal and no ATV has a differential, I never knew that, he said thats the reason why they are dangerous and they tip over. Is this true? Is there any ATV with a working differential?
Old Aug 20, 2006 | 10:35 AM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Most are like the Eiger with a non-differential rear end. It does not make them tippyand dangerous - mostly because they are not very wide. Yes, one of the wheels will slip when in a turn - that's why ATV's are made for off road and not for pavement use.
One of the little Kawi's had a rear end dif - think it was the old 220. The slightly modified 250 probably still has the same rear end. They used to advertise it for utiility use on yards or golf courses. I think one of the old Yamaha Moto-4's had the same setup. There could be a couple more out there.
Jaybee
Old Aug 20, 2006 | 07:54 PM
2manytoys's Avatar
Yes there are atv's with differentials. Actually all irs machines have a diff but not all are limited slip. Polaris has an option on some of the quads to have a turf mode. This unlocks one side of the rear diff so it wont tear up the grass. A differential will have a ring and pinion. All IRS machines have a ring and pinion. There are just different setups on differentials but all are considered to have a diff.
Old Aug 20, 2006 | 09:11 PM
v2rider's Avatar
Actually, to be technical, the rear "differential" is actually called the rear drive, and the front is called the differential.
Old Aug 20, 2006 | 10:52 PM
hondabuster's Avatar
The only two quads that have a rear diff, is one old bayou, and the polaris with box on back, im not aware of any other quad ( irs or solid axle) which have a differential in the rear. There are lots of irs quads which have a spool rearend ( outlander, outlaw, grizzly , kodiak, rincon and so on) in fact the only one which has a differential is that polaris .
Old Aug 20, 2006 | 11:18 PM
v2rider's Avatar
All irs models have a REAR DRIVE which looks identical to the front differential, and has the same fluid, and procedure to change as a front differential. Alot of people refer to it as a differential
Old Aug 21, 2006 | 01:35 AM
A differential on an axle means one side can rotate at a different speed than the other side.
Old Aug 21, 2006 | 04:35 AM
CaptainQuint's Avatar
I've ridden one of the polaris 2 up atvs with the little pick-up bed/extra set deal and it had a turf mode switch which unlocked a rear differential. Really saved the grass in the yard and made the thing steer and handle easier I thought. Kind of a slick little deal if it didn't compromise the strength of the rear drive section.
Old Aug 21, 2006 | 02:47 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Your solid rear axle means that you have "lockers" on the back end, so you are better off.
Old Aug 28, 2006 | 10:46 PM
ATV_MAN's Avatar
It doesn't mean you have "lockers", it's just locked all the time. Its just 2 gears meshed together.
Companies call it different names, Final drive, rear drive gear ect.
