raptor fan???
Old Aug 20, 2006 | 06:13 PM
fasterufool's Avatar
Default raptor fan???
i have a 03 raptor, the problem is that i have only seen the fan run a hand full of times.. now, since the motor has been built, im overheating.. how can i check to see if the fan works and what can i do to check my over heating problem?? i just changed oil, not milking. all of the coolant in the overflow tank shoots out. not much in the radiator is gone?? please help!!!! thankx
Old Aug 20, 2006 | 09:15 PM
DriverDoyle's Avatar
You will need a Metal Thermometer that goes up to arund 220..
You will need a Cooking pot
You will need a Propain tourch (or somthing like that)
You will need water..
Ok Take your fan sencer out of the bottom of the radiator...Put the metal part of the sincer in the water in the pan..Place your metal thermometer in the water too..Heat bottom of pan SLOWLY...{Do not heat up sincer fast it will not work right anymore} Ok watch your thermometer while you are heating the bottom of pan slowly..Your fan sould kick on around 202 to 205...You can test up to around 230 but i would not go any higher..If it was working right it would have came on before 210...
This is the easyest way i have found to test your cooling fan..Just dont put open flame on sincer..
I hope this helps..[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 20, 2006 | 11:52 PM
paintballbanshee's Avatar
wowoow i did that and mine did not kick in until 218..
Old Aug 21, 2006 | 01:51 AM
I think a rappy fan kicks on at 202 but i would have to look back in the book...The Thermometer your putting in the water to see how hot its getting can be off..Im sure the old one i use is off a little..But its a good way to find out if your fan is kicking on or not
Old Aug 21, 2006 | 05:27 PM
MasterRaptor's Avatar
The thermostatic switch lasts less than 2 years. I am on my third one. Just go buy another one.
Old Aug 21, 2006 | 07:55 PM
thanks guys for all the help!!!!!!! i will try these tings and post back.. once again thanks alot
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
