in dire need of help with my mojave
Old Aug 22, 2006 | 12:40 AM
advocate2469's Avatar
Default in dire need of help with my mojave
i am have troubles with my mojave. it is all stock that i know of. but the person that had it before me tore it down ad tried to rebuild it and i dont know if he timed it right. how do you time the darn thing? and is the kick start a hard thing to replace and is it a spendy fix? thanks advocate2469
Old Aug 22, 2006 | 01:30 AM
mojo21's Avatar
The mark on the exhuast cam sprocket should be lined up with the top of the head facing forward of the quad and the intake mark on the sprocket should be about 3 degrees up from being level of the head facing to the rear of quad, (one tooth up from level with head). All being done at top dead center which is the t mark lined up with the cut out on the case in the little hole where the plastic plug you take out of the mag case. Im 17 years old and do it. It should be simple for you if you understand me correctly. The kick starter should be a breeze to fix. Pm me if you have trouble.
Kenny
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
RidE
Oct 19, 1999 06:10 PM
dunc_n
Aug 26, 1999 09:32 PM
BlackHawk
Jul 31, 1999 01:31 AM
