04 700 EFI Won't Idle??
Old Aug 22, 2006 | 07:21 PM
TalonZX's Avatar
Default 04 700 EFI Won't Idle??
I have a 2004 700 EFI with 54 hours on it and it will not idle all of a sudden, unless you apply pressure to the throttle. New plugs and no codes. Any ideas??? Also, the wrench symbol is flashing on the speedometer when you first start it up but then it goes away. It also seems to always have gas in the oil since day one, I change the oil, ride it for an hour, check the oil and it is way over full??????
Old Aug 22, 2006 | 07:25 PM
v2rider's Avatar
My buddy has a sp700, and is having alot of problems also. He had to replace his whole throttle assembly to fix his problem, and it still doesnt run right
Old Aug 22, 2006 | 07:45 PM
SPORTSMAN70003's Avatar
Have you tried adjusting the ETC on your throttle? Are you running a K&N filter by any chance? The wrench symbol is set to remind you of service times. The dealer probably set it at the dealership. You can reset it by going into you diagnostic mode and the instructions should be in you owners manual.
Old Aug 22, 2006 | 08:36 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i just reset my counter on mine as well beacuse the wrench would come on. it was set for 50 hrs and counted down to 0 then the icon comes on. if you dont have your manual we tell you how to do it. if you have the book its on page 44. the idle is set by the factory an dthe dealer needs to adjust it. some people have posted their throttle body was dirty and it idled ruff. cleaned it and it fixed it. but that doesnt explain the gas going in the base.
Old Aug 23, 2006 | 09:19 AM
TalonZX's Avatar
I have not tried to adjust the ETC on the throttle, however I am running a K&N.
Old Aug 23, 2006 | 10:00 AM
If you run a K&N and over oil it the oil gets on the t-bap sensor which measures barometric pressure and air temperature and if you suck in enough oil it will cause your idle to go down as it gets on the throttle plate and causes it to not fully close....a quick cleanup of the throttle plate and idle will be right back up...
Old Aug 23, 2006 | 10:34 AM
TalonZX's Avatar
THANKS! I'll give it a try and let you know.
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
