help a newbie
Old Aug 23, 2006 | 10:43 PM
sizmaters's Avatar
Default help a newbie
im picking up an 03 pred. on sat in pa im in va anything to look for when i get there as far as common problems and such. the guy is letting it go for 2100 and i worry that something is wrong. thanx ahead of time for all your help
Old Aug 24, 2006 | 02:05 PM
tblazer's Avatar
All depends on how good the guy maintenanced it. Id look for cracks in the frame, mainly by the gas tank. Also, test drive it and make sure its not missing a gear. And id probly check the wheel bearings by taking ahold of the front tires and see if they wiggle or not. If so, you probly no it has been driven hard and may want to look for another or pay the money to have the balljoints replaced. Just my 2 cents!
Old Aug 24, 2006 | 02:46 PM
sizmaters's Avatar
thanx any one else?
Old Aug 24, 2006 | 09:04 PM
magnumLover's Avatar
hey t blazer my frount tires do that, also my handlebars more about 1 inch side to side and up and down before moving the tires, any idea how i can fix this?
thanks
Old Aug 24, 2006 | 09:21 PM
tblazer's Avatar
What kind of wheeler do you have?
Old Aug 24, 2006 | 10:34 PM
2000 polaris magnum 325, bearclaw tires(if it matters)
Old Aug 24, 2006 | 11:38 PM
tblazer's Avatar
For your steering post I would check the upper steering post bracket to make sure it's not loose and that the bushings are not worn. Worn bushings is usually what causes it to be loose. Being a 2000, the bearings and roll cup are probably pretty worn so you'de most likely have to replace them to solve the wiggle problem in your wheels. Hope this helps!
Old Aug 24, 2006 | 11:39 PM
how do i check the upper steering post
Old Aug 24, 2006 | 11:50 PM
tblazer's Avatar
Its just the upper part of the one steering post, but ya you may get by with just taking off the front panel cover but if you still can't get to it you'll have to take off the front plastics as well which should only take a few minutes. If the bracket looks loose to you or the bearings then taking off the gas tank to get at these will make it much easier to work around. You should only have to take out a couple bolts and unhook the gas line and it should slide right out.
Old Aug 25, 2006 | 12:03 AM
ok at the bottom there is a bolt that might be loose, this has a pin through it, should i remove the pin and tighten it?
thanks
