Whats my 400 motor worth?
Old Aug 24, 2006 | 11:45 PM
CincyScrambler's Avatar
Default Whats my 400 motor worth?
Hey guys I want to pick your minds about my motor is worth. Its a 98 Sport 400 motor that I bought for a project and lost interest in. It has the following:
Fresh Top End with a Wesico Piston .20 over
Head was resurfaced
new seals and gaskets throughout
new water pump impeller and seals
new counter shaft bearings
new crank bearings
trued crank
fresh reeds
HPD Oil-Injection Block off Plate
All the work was done at a Polaris dealer so its all perfect and ready to bolt in and run. Its spotless all the casses were diped to remove dirt and grime and the cylinder was bead blasted. Dont Know if Im going to part with it yet just curious of what you guys think its worth?
Old Aug 25, 2006 | 08:07 AM
ftwflh's Avatar
You should get $600 to $750 for it.
Old Aug 25, 2006 | 09:57 AM
scramblered's Avatar
i guess $1000 or even over,welding those crank cost some cash and new crank bearing is priceless...
Old Aug 25, 2006 | 06:38 PM
ftwflh's Avatar
You talkin Canadian or US dollars [img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 25, 2006 | 06:54 PM
ncriderforks's Avatar
Tough to say. The 98 back motors won't fit on the concentric frame. You will have to change the housing on the mag side so the coolant inlet will not rub the frame.
Old Aug 26, 2006 | 12:14 AM
Ive seen them go upwards of 800 on ebay for a nasty *** motor that the seller knew nothing about.
fd24
Jan 16, 2019 08:59 AM
caveeagle
Sep 19, 2015 01:20 PM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
