rejetting 06 hawkeye
Old Aug 25, 2006 | 07:49 PM
greenscreaminv's Avatar
Default rejetting 06 hawkeye
I'm planning on rejetting my wife's 2006 hawkeye and was wondering if it's easiest to pull the carb off in order to change the jet or does someone have a trick to get the bottom of that carb off?
Old Aug 25, 2006 | 08:34 PM
powerslider's Avatar
It's best to pull it off the first time as the bowl screws are very tight, an impact screwdriver is what works best for breaking them loose. They are soft screws and the head will strip very easy. Also while you have it off you can remove the brass plug over the idle mixture adjustment so that can be fine tuned. Remove the left air duct to the belt housing to get the carb out....
Old Aug 25, 2006 | 08:37 PM
Thanks for the tips. I think I'll probably tear into sunday if I can get a jet found.
Old Aug 25, 2006 | 08:44 PM
What elevation are you riding at?
Old Aug 25, 2006 | 09:09 PM
TennesseeTider's Avatar
I just did mine last night. I did not disconnect the choke or throttle cables. I used needle nose vise grip pliers to loosen the screws. I ride at 500-200 feet and I put in a 137.5 main and raised the eclip up one position as both are the new settings as in the latest online owner's manual for the 2006 Hawkeye.
Old Aug 25, 2006 | 09:16 PM
Our elevation is right about 5200 feet. I think it has a 137.5 in it and am planning on trying a 132.5.
Old Aug 26, 2006 | 08:30 PM
I finally got a jet today for my wife's 2006 hawkeye and what a difference it made. It's like a totally different machine. The jet it came with was a 137.5 and I rejetted to a 132.5. Didn't mess with the eclip. Before rejetting the throttle reponse was terriable. It you punched the throttle from a stand still, the machine would bog down and try to flood out. Now, the machine takes right off like it should have from the dealer. Our altitude here is just above 5200 feet. Anyone having problems with the hawkeye should be able to fix this problem with a simple jet swap.
Old Aug 26, 2006 | 09:19 PM
kfxandahemi's Avatar
I'd have to agree. After riding it before and after, doesnt even feel like the same machine. No more sputters and she takes right off with no bogging.
Old Aug 26, 2006 | 10:27 PM
Glad to hear your problem is fixed, if you ride in cold temps you may have to go back to the larger jet. Just keep that in mind...
Old Aug 29, 2006 | 10:20 PM
polarisWILL's Avatar
HERE'S THE FIX...........
If your dealer won't replace the jets and wants to drill holes, keep in mind the jets are under 10 bucks and the labor should only be about 30 bucks or so I was told. I'd rather spend the cash than have 6 holes in my airbox.
Carb Pre 3/7/06--------------------------- Carb Post 3/7/06 (The right one)
Main jet 147.5----------------------------------- Main jet 140
Pilot jet 42.5--------------------------------------Pilot jet 45
Jet needle 4HB42-5-------------------------------Jet needle 4HC57-3
Neddle jet 04-m-----------------------------------Needle jet 05-m
Post 3/7/06 Altitude--------------------Below 40 degrees F ---------------Above 40 degrees F
0-6000 feet ------------------------------------145-----------------------------------140
6000-1200 feet------------------------------- 140------------------------------------135 or 6 1/2 inch holes in top of airbox....(stupid)
According to Polaris the dealer can either replace the jets or (stupid) drill 6 1/2 inch holes in the top of the airbox and you can self adjust by removing the rubber plugs in those holes, again (stupid)
