Converting 2X scrammy to 4X
Old Aug 25, 2006 | 08:00 PM
bigike's Avatar
Default Converting 2X scrammy to 4X
Have any of you ever converted a 2x into a 4x? If so what did you have to do special and if not what problems made you stop.
Jay
Old Sep 2, 2006 | 10:46 PM
Quadaddy's Avatar
Hmmm, Funny you should ask. Actually I have just done the opposite...4x to 2x on my 2004 along with a weight reduction plan I'll soon have the quad I was after when I bought this one new. I found all the 2 wheel parts I needed on ebay using part # cross reference from a polaris web site. Had to change out the strut housings, steering shaft, and tie-rods are different length. Still using my transmission with the output shaft spinning. I may pull that out later and make a block-off plate. In your case you would also need to round up the throttle lever box that has the 4x switch, and the wiring harness not to mention the correct tranny. I don't think it would be worth the effort myself.
Old Sep 3, 2006 | 05:48 PM
x_scrambler3's Avatar
I think the frames in the front are differnt I don't think the 4X2 has the bolt holes or the space
Old Sep 3, 2006 | 06:03 PM
2manytoys's Avatar
It would be a waste of money and time. It would be cheaper to find a 4x4 Scrammy.
Old Sep 3, 2006 | 08:01 PM
Quadaddy's Avatar
Yepppp...and alot easier.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
125Gdaddy
Sep 14, 2015 02:12 AM
RNN
Sep 5, 2015 12:43 PM
chammerbeck
Jul 17, 2015 08:06 AM
polaris scrambler00
Jun 20, 2015 08:49 AM
