Ordered new part on rear differential, (plastic plug), is there something stronger than plastic?
Old Aug 25, 2006 | 10:56 PM
Baconbits's Avatar
Default Ordered new part on rear differential, (plastic plug), is there something stronger than plastic?
I had to order a plastic plug that goes on top of the rear differential on my bayou, because, ITS PLASTIC!!! Ive ruined the one on mine because its so hard to not tear up. Does anyone know where to get a metal one or something stronger than plastic?
Old Aug 27, 2006 | 12:27 AM
Baconbits's Avatar
Guess I cant get any help around here?
Old Aug 27, 2006 | 01:11 AM
BigOne's Avatar
Maybe nobody knows
Old Aug 27, 2006 | 06:17 PM
grizzkiller's Avatar
try to find a nut that fits that plastic plug, then go to a dealer to see if a metal plug from a different model fits the nut you have! thats basically what i did to find a new diff drain plug for the front of my brute but i just ended up getting a metric hex bolt, because the original was a allan head bolt that was ready to strip out. hope that helps!
Old Aug 27, 2006 | 10:15 PM
Baconbits's Avatar
Well are you talking about the size? 17mm is what I use to open it.
Old Aug 28, 2006 | 01:07 AM
no, the size you open it up with is different than what it threads into. take the plug to a hardware store, find a regular old nut(probably metric) that threads on to the plug. then that will tell you what size you need. you can probably find a new bolt that fits that nut that is made of metal instead of plastic, the only reason i say try a dealer for another drain form a different model is that regular bolts matbe too long for a differential.
VRRRRT
Jun 27, 2015 09:38 AM
scaldwellk
Jun 19, 2015 05:08 PM
wildbill59
Jun 9, 2015 02:28 AM
