tire preasure?
Old Aug 27, 2006 | 12:30 PM
notmydayjob's Avatar
Default tire preasure?
Dealer says 5psi. Side wall on the Carlise XTRa says "do not exceed 36psi". At 5 lbs the side walls role and the steering is heavy. At 8lbs the steering is lighter and it seem more balanced in the corners. How much pressure are you guys running?
Old Aug 27, 2006 | 12:57 PM
v2rider's Avatar
36psi???? That is probably just a mounting pressure. I run 6.5 in my swamplites. Ive heard of people running as high as 9 0r even 10. I would just find a pressure between 4 and 7 that you like the feel of, and go with it. I had to experiment a little to find the right roll, traction preference, ect......
Old Aug 27, 2006 | 06:43 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
thats the max inflating pressure your seeing. i run 5.5 lb. most of the time w/ my xtr's w/ pretty good luck.
Old Aug 28, 2006 | 10:26 PM
lslubecki's Avatar
I run 6-7 psi. I used to run 25 psi in my honda when I first started trail riding. No traction. Felt like I was on ice when it was a little slick.
Steve
Old Aug 28, 2006 | 10:27 PM
lslubecki's Avatar
All my scrambler buddies run 5-6 psi.
Steve
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
