Raptor Brakes HELP!!
Old Aug 28, 2006 | 07:32 PM
smoovlatino's Avatar
Default Raptor Brakes HELP!!
I was having trouble with my brakes... well, after bleeding them with a bleed kit, I got the front brakes to work. After about 5 minutes of testing the brakes, I noticed it was spongy and not braking as hard. When I tested the brakes while looking at the caliper, I saw fluid leaking from the Union bolt and copper washer on the bottom of the caliper (where the brake line attaches) every time I squeezed the brake lever. No problem I thought... I'll just replace the brake lines. I cannot get the union bolt off for the life of me! I've tried everything and I am stripping the bolt in the process. Is there a special way to do this? Anyone have any ideas?
Old Aug 28, 2006 | 07:38 PM
Bump
Old Aug 28, 2006 | 08:14 PM
JLsparky7's Avatar
Try heating it up, the caliper will expand and the bolt will stay cold.
Old Aug 28, 2006 | 08:24 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Take a lil ball peen hammer and tap the bolt head while you have tension on the wrench.
Old Aug 28, 2006 | 10:06 PM
OK... I'll try heating it up and striking it....
If and when I do get the bolt off and order new brake lines, do the new lines come with copper washers?
Old Aug 28, 2006 | 11:22 PM
JLsparky7's Avatar
Probably depends on the kit you get. I would call the company first and ask.
Old Aug 29, 2006 | 01:04 PM
OK... I've tried heating the metal components up, striking it with a hammer, everything I could this morning and ended up stripping the bolt even more. What else can I do with this stubborn bolt? I'm going to try soaking it with WD-40, but I highly doubt that will do anything.
Old Aug 29, 2006 | 02:13 PM
hondabuster's Avatar
Theres no reason that bolt should be that tight. But if it is, it might be time for an air impact wrench. You might have to use a inch socket, and maybe even have to hammer it on, to get a good bite.
Have you tried a chisel? tap the bolt in the direction of loosening.
You can get those copper washers at any napa store if the new lines dont have them.
Old Aug 29, 2006 | 02:29 PM
Monkey Rider
Afro-Engineer
you could maybe try turning it the right direction [img]i/expressions/face-icon-small-wink.gif[/img] Left loosy righty tighty man. I have never had a problem with them brakeline bolts freezing up. before you strip the head you should snap the bolt. what kinda wrenches were you using?
bmark0610
Sep 9, 2015 10:56 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
black_thunder
Sep 7, 2015 01:24 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
