o4 polaris sportsmann 500HO
Old Aug 29, 2006 | 08:54 PM
bigstubby's Avatar
Default o4 polaris sportsmann 500HO
Having problems with no / low power in high range. Can't get it to go over 25mph, acts like bad gas or spark plug. Checked both, also replaced drive belt. It sputters & misses when driving it, low range a little better but not much. What should I be looking for. Dealer told me sounds like electrical.
Old Aug 30, 2006 | 09:25 AM
Kerbbirds's Avatar
Check the slack in your throttle cable, should be very little, adjustment is about 4 inches from thumb throttle, to much slack causes the etc, electronic throttle control to engage like the throttle was sticking.Hope this helps.
Old Sep 1, 2006 | 06:35 AM
bigstubby's Avatar
I checked the slack, there was a little. I tighten it up, didn't help . Thanks for info. Ordered shop manaul, maybe I can locate problem.
Old Sep 5, 2006 | 06:52 PM
Gern's Avatar
Had a similar problem with my '04 Sportsman. I thought bad gas, spark plug etc. For mine, the answer was wayyyyy too simple. I pulled the air fliter and found that it was packed with fine dust from a couple of trips to the local mx/atv area. Blew it out with the compressor for a quick fix then replaced later. Wow, imagine what a clean filter will do (felt like a complete idiot). Not sure if this is your problem, and maybe you've already looked at that, but your problem sounds identical. Hope this helps....Gern
Old Sep 8, 2006 | 10:30 PM
bigstubby's Avatar
Replaced air cleaner in May, looks fine. I tried to take carb off but can't figure out how to get throttle cable off of carb. Service manual no help. Any ideas?
Old Oct 1, 2006 | 11:22 AM
bigstubby's Avatar
Finally found problem. Cleaned carb & it stilll was running like crap. I took off ams airfilter (which is foam) & put old air filter on. Well it ran fine then. Foam filter didn't look dirty.
Old Oct 4, 2006 | 02:07 AM
Gern's Avatar
Glad to see that you found the problem. Love my '04 500 ho but now thinkin' I need the 800 efi. Wife and bank both say yes, so now just have to get off my duff and go for it. We'll see....Gern
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
