300 bayou tires, and valves
Old Aug 31, 2006 | 12:04 AM
Hainitracing's Avatar
Default 300 bayou tires, and valves
just wonderin whats the advantage/ disadvantage of running the same tire all the way around ...and does anyone know what the valve spec on a 2000 bayou is?
thanks all
Jeremy
Old Aug 31, 2006 | 03:19 PM
alwaysride's Avatar
run the same tire size as stock. Dont have big tires on the back and small on the front because that will cause problems with the drice components. Im assuming this is a 4X4 atv right?
Old Aug 31, 2006 | 04:44 PM
yes its 4x4... right now there is 24x8-11 front and 24x10-8 rear and i was wanting to go 24x8-11all the way around think it would be ok?
thanks
Jeremy
Old Aug 31, 2006 | 05:10 PM
Hayashi's Avatar
As long as you keep the overall OD of the tires same, no problem with 4x4 system. However, since you want to put narrower tires on the rear, you may have traction/handling problem depending what kind of riding you are doing and how slippery the terrain is. Let us know.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
rcappie4
Jul 18, 2015 07:51 AM
Sjrpp
Jul 5, 2015 09:04 PM
