Jumpin Your ATV
Old Sep 1, 2006 | 12:37 PM
phour20inwi's Avatar
Default Jumpin Your ATV
i own a 01 trailblazer 250 and whenever i hit jumps i have the problem of the fron end dropping to fats on me, the jumps are only about 3 foot buts its still hard on my arms, ive even tryed poppin harder on the throttle to get more lift when leaving jump but still dont help, even leaned all the back as far as i can go, anyone how to stop this or somethin i might be doin wrong?
Old Sep 1, 2006 | 01:00 PM
06LimitedPred's Avatar
Here's my best advice, get a real sport quad lol
Not trying to rag on ya, but those 250's are ok for this or that. If the fronts are bottoming out when landing, even when landing more on the rear tires then maybe you could replace the front shocks or put in new springs, maybe they're just worn out.
Old Sep 1, 2006 | 01:20 PM
BryceGTX's Avatar
Hello phour20inwi. The Trailblazer is a great jumping quad. I regularly put mine 3-5 feet in the air and flat land it. If you land on the backside of a hill, you can go much higher. To jump it, you should hold the throttle open till after you land. If you let off on the throttle either prior to lift off or in the air, the front end may go down. Any change in throttle causes the quad to rotate around the rear wheels. It is how you can change the attitude of the quad in the air. Similarly, if you find the front too high, let off on the throttle or tap the rear brake to bring it back down.
I hope this helps,
Bryce
Old Sep 1, 2006 | 01:40 PM
thanks for all the help, i will have to try your advice tomarow, thank again
Old Sep 1, 2006 | 01:53 PM
v2rider's Avatar
I jump my 700 lb quad all the time. You just have to hit the throttle right as your going to leave the "ramp".
Old Sep 1, 2006 | 02:04 PM
ah now i get you, you mean that no matter what you're unable to get the front end from nose diving when you jump, that's not too hard to fix, stay on the gas instead of wimping out and letting off.
Old Sep 1, 2006 | 02:09 PM
scootergptx's Avatar
Supersock
Hired Gun!
Watch some of the pro's on video. You should see them "working" the brakes. If they don't have loud background music, you can hear them working the throttle too.
yamikodiak07
Aug 6, 2009 10:54 AM
gerkendave
Nov 14, 2008 04:45 PM
sassee
Jan 11, 2008 07:46 AM
hinglbyds
Oct 2, 2004 12:25 PM
trx430ex
Aug 19, 2000 11:25 AM
