Bearing on end of primary clutch
Old Sep 3, 2006 | 09:36 PM
MarkGleason's Avatar
Default Bearing on end of primary clutch
This is on a 2005 360 prairie.
A few months ago the engine brake stopped working right. It was always engaged. We took off the engine brake arm and unplugged the motor. The quad worked fine and we didn't even miss the engine brake.
Today there was a thumping sound coming from the belt cover so we pulled the cover off and the bearing from the end of the primary clutch had fallen out.
It looks to me like all this bearing does is provide a place for the engine brake arm to push against. Since we took the engine brake arm out this bearing should not be needed. Am I correct?
Old Sep 4, 2006 | 02:26 AM
alwaysride's Avatar
Not possitve but im pretty sure it is needed.
Old Sep 4, 2006 | 06:58 AM
montyh's Avatar
the bearing is just for the fork from the KEBS to contact. as long as you do not use the enginge brake, it is just dead weight.
you can just leave it out.
monty
STLyamwar
Jul 25, 2020 04:44 AM
robert301972robert
Aug 30, 2015 11:34 AM
4464
Aug 21, 2015 01:46 AM
mitchxc700
Aug 19, 2015 02:41 AM
clsharky
Jul 13, 2015 02:07 PM
