Weird Idle Problem On 500 Sportsman HO
Old Sep 5, 2006 | 06:12 PM
Bushright's Avatar
Default Weird Idle Problem On 500 Sportsman HO
2004 500 Sportsman will not idle with the handlebars straight ahead, but crank them all the way to left hard and it idles fine. Any ideas on how to solve this problem? Thanks in advance.
Old Sep 5, 2006 | 06:29 PM
2manytoys's Avatar
Yes there is an adjuster up by the throttle. If the cable is too tight it will idle up when you turn. You need to turn the adjuster in till it does not do that anymore. Then turn the idle up on the carb till it idles good. You should be ok once adjustments are made.
skittero
35
Mar 1, 2019 12:39 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Raccar1
Jun 18, 2015 02:17 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
sae156
Jun 3, 2015 01:45 PM
