Lost power
Old Sep 5, 2006 | 11:47 PM
dmedicineman's Avatar
Default Lost power
I have a 2003 Sportsman 500. I hadn't ridden it in about a month and a fouled out the sparkplug trying to crank it. I changed spark plug and it ran fine for about a week. I attempted to start it up today and something popped.....not loud very suddle....like a fuse. Now there's no power at all when the key is switched on. Battery is good. Is there a fuse located somewhere that could have blown? Any suggestions?
Old Sep 6, 2006 | 10:23 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default Lost power
Is anything lighting up just with the key turned ahead with out starting it......caper.......ex headlights,guages,
Old Sep 6, 2006 | 10:38 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Lost power
there is a few in line fuse links i beleave one is in the battery cable area.
Old Sep 7, 2006 | 04:31 PM
Default Lost power
Nothing lights up when the key is turned over.....no gauges etc.
Old Sep 7, 2006 | 10:27 PM
Default Lost power
Get a voltage tester......ground it to the battery......start testing the power wire back from the battery until you find the fuse or until you loose your 12 volts.........also Stenroi.....on your 450 sportsman......I checked under the plastic cap(FRONT STORAGE RACK) where the rad cover is and no fuses there.....I thought I read in a post that they were under there.......THANKS....caper.......
Old Sep 9, 2006 | 11:00 PM
Default Lost power
When I first posted this I thought I did all my home work. I first replaced the battery and went from there. Unfortunately the battery that I replaced was also bad. So after all the good posts it seems the demon was another bad battery after all. After a 3rd battery all is well. Thanks for all the input.
2quiker
Mar 22, 2022 08:36 PM
black_thunder
Sep 6, 2015 04:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
