700 efi maintenance
Old Sep 6, 2006 | 03:47 PM
jdaddy's Avatar
Default 700 efi maintenance
doing yearly oil change and tranny fluid change and noted that polaris recommends different fluid for, tranny, front, and rear gearcase(s). anyone know if i use polaris AGL gearcase lube (transmission oil) in the frt and rear rather than the (premium demand drive hub fluid), and (atv angle drive fluid) respectively, would this cause problems? the manual says to use 5 oz. in frt and rear. can't see the need to buy three products when 1 qt of the tranny oil would do the job??
Old Sep 6, 2006 | 06:41 PM
patrolman800's Avatar
bad idea use what they say there is a difference in the weight of the oil
Old Sep 6, 2006 | 08:01 PM
jdaddy's Avatar
i talked to the dealer, he said the front gear case needs the different fluid, the rear gearcase and trans. are the same.
Old Sep 7, 2006 | 04:59 AM
jimmypsp700's Avatar
Wrong!
Use the Demand drive in the front diff and the AGL in the trans.
For the rear diff you can use any quaility full sythentic 80w-90 gear lube.
I know I won't stray from the (PPD) Polaris Premium Demand Drive (Synthetic) fluid in the front Differential on my sp700.
Jim
Old Sep 7, 2006 | 06:43 AM
UTU's Avatar
UTU
Originally posted by: jimmypsp700
Wrong!
Jim
Jim is right on. Better check on your dealer for giving out the WRONG info! Could be very costly to YOU!
Old Sep 7, 2006 | 05:49 PM
jdaddy's Avatar
I used the demand drive fluid in frt. and the AGL in the tran. and rear gearcase. what is with all the different hardware hex. torq.???
Old Sep 7, 2006 | 08:09 PM
UTU's Avatar
UTU
Jdaddy, Polaris calls for 85-90 gar oil for the rear gearcase. I use synethis in all including the rear. AGL will be way too light in weight for the rear!
Old Sep 8, 2006 | 10:25 AM
jdaddy's Avatar
thanks for dialing me in, i'll be draining the rear gearcase, and putting the proper fluid in before running around placing treestands up.[img]i/expressions/face-icon-small-blush.gif[/img]
dannytas
Sep 26, 2017 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
caveeagle
Sep 19, 2015 01:20 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
