Whos Making Aftermarket RAPTOR CLUTCHES?
Old Dec 3, 2000 | 09:32 AM
x250rDude's Avatar
Has anyone changed the clutch with an aftermarket one yet?Im thinking maybe barnett but not sure if its available yet.Any help would be great.Clutch went soft on me the other day while in a tight trail while feathering it.Had to wait till it cooled down then it came back.Im thinking a good heavydudy clutch and spring set should tale care of this.
Old Dec 4, 2000 | 11:10 AM
ERICsRAPTOR's Avatar
Barnett has Kevlar clutches.
Friction plates: #YPK-13CF (6 required) and #YPK-25B (2 req.)
Steel plates: #YP-15-12 (7 req.)
Springs: #MT-45-5
The friction plates retail for $10 each, steels are $4 each and the springs are $12 per set.
Old Dec 4, 2000 | 11:20 AM
bash's Avatar
You can reuse you steel plates if they aren't burned up.
Also, from what I understand, the Raptor and Banshee clutch plates are the same, but the Raptor requires an aditional 1/2 width clutch plate. The steel plates are slightly different with the Banshees being slightly smaller in the tooth area. Also, the Banshee uses six springs, the Rapter uses 5. I've got a Barnett Dirt Digger clutch. No problems so far!! It still has an easy pull, but somewhat firmer engagement. It just feels a little sturdier.
Old Dec 7, 2000 | 02:28 AM
86atc250r's Avatar
Don't you mean aluminum? Or does the Raptor have steel plates?
Old Dec 7, 2000 | 09:39 AM
bash's Avatar
From the best that I can remember, they looked like and felt like steel plates. Isn't that what the Barnetts are as well? I watched the mechanic clean on them before we reused them and they looked a lot tougher than aluminum. Is this unusual? Maybe I am mistaken?
Old Dec 7, 2000 | 10:08 AM
Raptorrider2001's Avatar
Does the Barnett Kevlar still have an easy pull?
Old Dec 7, 2000 | 10:48 AM
bash's Avatar
Yes, it's still fairly easy to pull.
Old Dec 7, 2000 | 01:37 PM
86atc250r's Avatar
Aluminum plates are typical from the manufacturer, but you never know, they could have used steel...
Steel provides some flywheel effect and doesn't pollute the oil as fast as aluminum will... Aluminum is lighter and will let the bike rev faster.
Yes you can get steel Barnetts, I'm not sure if they offer a choice.
Old Dec 7, 2000 | 02:48 PM
Hey do you need a perch for that MSR lever? Also I remember when you first put them pictures up and then you said new pictures added 11/15 and I looked and couldn't find any. Whats up with dat!
Let me Know
Old Dec 7, 2000 | 10:53 PM
x250rDude's Avatar
So barnett is not selling a complete kit just selling the parts seperetly???That does not make much sense.Also I heard you had to unbolt the whole engine and move it up to get to the bottom bolts?Is this true?
1966F100
Jul 12, 2015 03:08 AM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
Dirtbikemike1
Jul 9, 2015 01:27 AM
yambam13
Jul 4, 2015 01:49 PM
