What should i do
Old Sep 10, 2006 | 01:37 PM
baja02's Avatar
Default What should i do
i have over 12,000$ invested in my DS-650. I just had to install a whole new front end due to a friend smashing it up. Now my engine just started to leak oil down the center gasket, which means i need to split the whole engine jjust to install a 20$ gasket. should i go crazy and install a ron woods stage 2 kit while i have it split? Or should i leave it stock?
I am all ready running ...
complete trinity exhaust system(which i dont like) 13, 000$+
umi CDI box
dynajet stage 2
hp rectifier
k&n filter
barnett clutch
fireball aarms
durablue axle
fireball steering stem
should I ride it till she blows, or invest another 3500$
ron woods stage 1&2
high performance rectifier
17,000$
I have so much invested in it I dont know what to do
Old Sep 10, 2006 | 03:57 PM
DragonDJ11's Avatar
Those are choices only you can make. You would not be unhappy with the upgrades in power, theyt will make you smile for sure. But again, just fixing the gasket is only time and a bit of cash. The other is time, and more cash.
Old Sep 10, 2006 | 05:35 PM
DuneRider650's Avatar
I ride a little here and there......
If you are not doing the engine work by urself....it would be cheaper to get these parts installed at the same time due to it only being ripped apart once then..but if you do all this work by urself and on your own time the cheap option for now would be to just change the gasket like dragon said.
