Hair Spray to put on grips
Old Sep 12, 2006 | 06:10 PM
BlazinBlu's Avatar
Default Hair Spray to put on grips
Was told to use hairspray to put on grips, what do everyone use? I was also told to use spray paint.
Old Sep 12, 2006 | 06:48 PM
squeege's Avatar
Yes..... a local bicycle shop told me the same thing
Old Sep 12, 2006 | 07:05 PM
BlazinBlu's Avatar
Told you to use what, hair spray? If so did you use it, and did it work?
Old Sep 12, 2006 | 07:09 PM
kfxandahemi's Avatar
You can use hairspray. It works fine, it acutally worked better than the Scott Grip glue I used once.
Old Sep 12, 2006 | 07:29 PM
holeshotz8436's Avatar
as you already know my vote is for spray paint......if you use hair spray or grip glue your grips will be sliding all over the place.....just 3 quick shots of paint in each grip then put em on and leave them alone for about 15 minutes......
Old Sep 12, 2006 | 07:32 PM
Never thought of spray paint before. Thats a good idea.
Old Sep 12, 2006 | 10:21 PM
BlazinBlu's Avatar
Put grips on first, or brake and throttle cables first, then grips? Gonna try spray paint and hope it works, thanks.
Old Sep 12, 2006 | 10:28 PM
put the grips on last......
Old Sep 13, 2006 | 04:08 AM
Scott3710's Avatar
I have been using hairspray when installing new grips since early 80's and never had a problem.
Old Sep 13, 2006 | 06:37 AM
Williebee's Avatar
My quad had grip's on it when i bought it new in Feburary 2006 !!!!!!!...............williebee
