HELP...No owners manual for 250EX !!!
Old Sep 13, 2006 | 03:22 PM
MrBaldone's Avatar
Default HELP...No owners manual !!!
I just bought a 2003 250EX. It came without the owners manual.
Whats the routine to check the oil?
How do I adjust the automatic clutch?
There is a plug under the seat by the battery thats taped up with nothing plugged into it. What could this be for?
Thanks...until I get a manual.
Is there a download manual for this ATV?
Old Sep 13, 2006 | 04:43 PM
bombrider04's Avatar
Default HELP...No owners manual for 250EX !!!
I would give the dealer a call and see if they can give you an owners manual since you did just buy the bike.
Old Sep 13, 2006 | 06:36 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
You found the dipstick on the left side, right??? Warm the engine up, then let it sit for a few minutes. Unscrew the dip stick, remove it and wipe it off, then dip it back in (but don't swrew it!), and that is your oil level. THIS IS HOW YOU CHECK THE LEVEL ON ALL HONDAS.
I suggest you change the oil first thing. Who knows what the previous owner did (didn't even have an owners manual after all). Takes a little less than 2 qts.There is no oil filter to change. There is a screen and a centrifugal cleaner that should be cleaned by the dealer. Some basic oil info: http://www.thumperfaq.com/oil.htm
Also, for the same reason, adjust the VALVES right away. You don't know how badly it was neglected.
Adjust he clutch when you get a manual.
Old Sep 13, 2006 | 06:49 PM
MrBaldone's Avatar
Thanks for the info.
wendal
May 9, 2024 09:29 PM
Customer Service #1
May 15, 2020 08:46 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
tombrown14
Aug 31, 2015 03:53 AM
