Are wheel spacers a good idea?
Old Sep 17, 2006 | 05:19 PM
dude61's Avatar
Default Are wheel spacers a good idea?
Some of my friends and I were talking about wheel spacers. Are they a good Idea or not because I heard they put a lot of stress on your wheel barings and it makes them wear out. Is that true?
Old Sep 17, 2006 | 08:16 PM
JimmyHoffa's Avatar
Front wheel spacers are a joke. Not only do they put lots more radial load on the bearing, they drastically affect steering. (especially bump steer) Rear spacers don't endanger parts, but they aren't as strong, and ad another way for you wheel not to run true. Moral: you can get away with backs, but it's better to have a skinny quad without fronts than to have a wide quad because of them.
Old Sep 17, 2006 | 08:17 PM
JimmyHoffa's Avatar
Oh Crap. Whoops. WELCOME!
Old Sep 17, 2006 | 11:12 PM
Scooter86's Avatar
Knows Old ATV Questions!
Wheel spacers will give you more stability, but there are some downfalls. They tend to stress and break components if you are jumping a lot since that extra width adds leverage. A sport quad with a solid rear axle may bend an axle with a one wheel landing. You will see more bump steer and have more feedback through the bars with spacers too. They are a great way to add width for cheap, but I would save up for a-arms and an axle if you are into racing or big air. You could always change the offset of your wheels to add a bit of width to.
Old Sep 18, 2006 | 08:31 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
On what machine???????
I only run spacers for a very short time on a new quad, to decide what extended a-arms might be like.
A good way to go a little wider, is get some rims that are wider and have more offset than stock. Combine that with some wider tires, and you can get as much as +3" real easily.
Old Sep 18, 2006 | 05:28 PM
dude61's Avatar
I thought about getting them for my 03 300ex because it doesn't feel stable on sharp turns. Thanks for the information.
Old Sep 18, 2006 | 05:38 PM
nathanpri08's Avatar
Whats up dude 61 we just talked about it the other day.I told you so.See you next weekend at moms house im bringing the ds if its done.If i do you should bring you 450r to put around on.
Old Sep 19, 2006 | 01:15 AM
Red Rider
I'll bet you are running those balooney stock tires, right???? If so, LOSE THEM! They do make the machine kind of tippy, and tend to push in turns.
Get a set of the new radial ITP TrakStars on T9 rims, and it will be a whole different machine! Did this on our 250EX's.
http://forums.atvconnection.com/mess...did/501664.cfm
Old Sep 19, 2006 | 10:36 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Spacers are just a bad idea for anybody that gets off the ground.
Old Sep 19, 2006 | 10:53 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Yep, I know someone that put them on a Blaster, and they even bent on that light of a machine.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
