What Mods Next??? How much hp???
Old Sep 18, 2006 | 01:38 AM
mrdonthate's Avatar
Default What Mods Next???
Well I Finally got my LTE's properly jetted. These things are awsome. Popping wheelies without effort in second gear. I only rode them for a few minutes to test them out. I guess you can look at the sig and see what mods i have. I am tring to get any suggestions on what to do next I mostly do trails but i would like something that will give 700s, predators, yfzs, etc a run for their money when i do race my friends for fun. I guess a good price would be a $800 budget. Also anyone know how much hp and mph they're getting with their mods.
any suggestions???
Old Sep 18, 2006 | 02:01 AM
JLsparky7's Avatar
cam, or high compression piston. Im a suspension guy myself, so id look into suspension and brakes before power.
Old Sep 18, 2006 | 01:52 PM
Raptor149's Avatar
I agree with sparky. Get good suspension and learn to ride it, then build a motor that your suspension can handle.
Old Sep 20, 2006 | 12:11 PM
mrdonthate's Avatar
So I'm now considering the cam and high compression piston. Im going to go with a stage 1 cam since LTE Duals are a mid & top end pipe. IM going with an 11:1 high compression wiseco stock bore piston. Any comments (good or bad) on using that combination? To install these two will this be all that i need (below). or is there anything else to buy along with it? (i see something about a piston pin bearing and top end gasket but it is an extra $52)
STAGE 1 HOTCAM
HIGH COMPRESSION PISTON
Old Sep 20, 2006 | 05:11 PM
ds650ctracing's Avatar
You will also need a Raptor Top End Gasket kit.(gaskets, seals)
Old Sep 20, 2006 | 05:15 PM
JLsparky7's Avatar
STAGE 1 HOTCAM
If thats what you decided on then try out www.rockymountainatv.com they might have it cheaper. Not to mention they have excellent customer service and theres 0 possibility that you will get screwed.... unlike ebay....
Old Sep 22, 2006 | 12:29 PM
mrdonthate's Avatar
If take the set up i have now and add the stage 1 hotcam and 11:1 high compression stock bore piston, how much hp (estimated guess) do you think i will be putting out?
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
