2001 trx250 recon clutch issue
Old Sep 20, 2006 | 12:54 PM
Unforgiven's Avatar
Default 2001 trx250 recon clutch issue
I just purchased a 01 recon and the guy i bought it from said the clutch was bad. Can anyone tell me where to go to find a downloadable manual for this quad. Fixing it up for my kids. Needs alittle work,....brakes,.....tires,......front bearings,.....and the clutch,.........but got a heck of a deal on it,......
Old Sep 20, 2006 | 01:06 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Have you tried just adjusting the clutch???? Procedure is in the owner's manual, if you have one........
Old Sep 20, 2006 | 01:52 PM
Unforgiven's Avatar
that's a big negative,....... So much info on the WWW figured i might find one to download. I've searched but haven't found one yet.
Old Sep 21, 2006 | 05:52 PM
tymann09's Avatar
i'd just get a clymers manual, they cost about 30-40$ and i must say its been very well worth it...itll tell you whatever you want
Old Sep 25, 2006 | 11:36 AM
Unforgiven's Avatar
ok guys,... cranked the ATV and removed the side plate by the tranny,....put it in gear the shaft turned so it's not the clutch. I then moved to the rear end. took the fill plug out of the top where i could look at the ring gear. Seems to me the ring gear is striped on the shaft. Went to BikeBandit.com and found a shaft for $100+ and a ring gear for $218,...........sigh,......may look for a good parter,......any suggestions?any help is deeply appreciated,......
skinnyr6
Aug 25, 2023 02:18 AM
Unzzy66
Jul 11, 2015 10:01 PM
200es
Jul 10, 2015 09:09 AM
Albertascramblerx
Jul 8, 2015 11:56 PM
MNatv89
Jul 7, 2015 11:36 AM
