Toe in?
Old Dec 4, 2000 | 11:33 PM
Mudskipper's Avatar
87 trx 4x. It is real squirrly at speed, on logging roads. Any one know what the proper toe in should be. Thanks for any help.
Old Dec 5, 2000 | 09:47 AM
BigRed450's Avatar
Should be TOE-OUT for stability not Toe-in. Generally speaking, about 1/4" of Toe-Out should work fine. Personally I prefer 1/4". I don't have the actual spec for your machine, but the average for 4X4 utility seems to be 1/4" to 9/16".
I have a procedure for front end alignment on the Tech Tips page of my website (link below ).
Old Dec 5, 2000 | 01:37 PM
Mudskipper's Avatar
Thanks. They were all diff. dir. when I got it and I figured a slight toe in would be proper but as I said.........it is haerd to keep on the loggin road at speed. Will try your adjustment. Thanks again
Old Dec 5, 2000 | 02:57 PM
BJBlomert's Avatar
According to All-Terrain Vehicle 1988-1992 Maintenance Manual, 1st edition, Volume 2(Intertec Publishing) the Toe-In should be zero for the Honda TRX 350 and TRX350D.
Hope this helps.
Old Dec 5, 2000 | 03:26 PM
snowshark's Avatar
Never go Toe-in, if anything get it as close to neutral as possible.
Old Dec 5, 2000 | 07:58 PM
Mudskipper's Avatar
Thanks again ,all of you. Will start with the neutral. No wonder it acts up. Thing sure is a tractor.
Old Dec 5, 2000 | 08:25 PM
Trick400EX's Avatar
humm..never toe-in on a utility quad... Always toe-in on a sports quad
