ITP 26" XTR's
Old Sep 22, 2006 | 08:02 PM
AnywhereTom's Avatar
Default ITP 26" XTR's
Has anybody running these tires experienced the front end shaking violently at speeds over 40mph, I have them mounted on the series 7 rims and when I get up to 40 and over the handle bars shake quite a bit, just wondering if maybe I have a screwed rim or tire on my front end, just picked up my new 07 800 stealth last week and finally got it out for a ride and can't go to fast because of the shaking, it makes the quad start to wander all over.
Old Sep 22, 2006 | 09:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you have a problem some where for sure. i have 27" xtr's on my 800 w/ the same rims and over 60 mph no vibrating. is one of the tires bad maybe? if its new i cant imagine having front end problems is everything tight? who mounted the tires on the rims and on the bike, are they on right. just a few idears. if anything i would take it to the dealer and let them know very its brand new.
Old Sep 22, 2006 | 11:26 PM
SAshton's Avatar
make sure your in 2wd. mine will shake in awd on pavement
Old Sep 23, 2006 | 12:15 AM
powerslider's Avatar
Balance the tires, spin balance to correct the static and dynamic imbalance. I had the same issue with the stock tires on my 800, the factory balance was only for static and I had major dynamic balance problems (bar shake). You need proper weight placement near both tire beads to correct this...
Old Sep 23, 2006 | 02:16 PM
Thanks I'll have them checked.
Old Sep 23, 2006 | 03:45 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
most atv tires are'nt balanced. no where near to being true around like a car tire.
Old Sep 23, 2006 | 05:54 PM
spyder6's Avatar
they still should be ballanced
Old Sep 23, 2006 | 06:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i guess ive been lucky spider because ive never balance any of my tires when ive changed them over.
Old Sep 23, 2006 | 08:37 PM
spyder6's Avatar
i guess so.
Old Sep 24, 2006 | 09:16 AM
thedon's Avatar
The front end of my machine feels very light at high speeds (40+ MPH). The whole machine vibrates a little but that is what I expect I guess.
The XTRs are a little heavier than the PXTs but other than that they don't feel much different once you are above 25mph or so.
I don't know about balancing tires on a 4 wheeler - mine is constantly slaming into rocks , treees etc so even if the tires were balanced it would only last for so long. It might be necessary for higher speed runs on pavement?
